2002 Z28 rear differential wiring
Old Jun 23, 2021 | 03:21 PM
vipe155's Avatar
Default 2002 Z28 rear differential wiring
Hi everyone,
I'm working on the suspension of 2002 Z28, cleaning (still work to do there), new shocks, etc. and I noticed a couple of unhooked connectors back there. The car was in a shop recently for a rear shaft seal & diff fluid change, so it probably was left this way after that. The connector plug on the top of the differential has nothing going to it, but I'm haven't seen any unhooked wiring hanging around the area. Also, the top opposite side there is some wiring support that I'm not sure where to bolt it to.
Old Jun 26, 2021 | 04:53 PM
ABS maybe? Has the rear end been swapped with a non ABS?
Old Jun 29, 2021 | 02:05 AM
dixkau's Avatar
I have a '16 so I dodged this bullet See you on the next.
192.168.100.1 192.168.1.1
Old Jul 6, 2021 | 06:51 PM
vipe155's Avatar
Bit of a late reply, but after research it seems someone swapped in a 3 channel rear instead of the 4 channel. So it works, but there is nothing to plug into the top of this diff and all that. No TCS/ASR vs. the original differential in the car. No idea why someone did all that just to get rid of traction control.
Old Jul 6, 2021 | 08:55 PM
They may have munched the original rear end and that is what they found to replace it with.
AbuZnood28
Jun 8, 2020 02:56 PM
kyphur
Sep 15, 2011 10:21 AM
justweldit06
82-92 V8 Tech
Oct 24, 2010 01:46 PM
JGRAHAM
Oct 6, 2009 03:10 AM
mongo
Dec 21, 2006 10:48 PM
