2002 3.8 in a 96
Old Nov 21, 2008 | 07:59 PM
Default 2002 3.8 in a 96
I have a 1996 3.8 (5 speed) with some internal engine issues. I found a 2002 3.8Camarowith 47K
I am getting the engine complete. It is my understanding the the only thing I have to change is the throttle body a cable linkage. Has anyone done this upgrade? Can i really use all the 2002 sensors and accessories/brackets with my computer system?
Another question. I am told the exhaust manifold are better flowing the my stock 96. Will my Y pipe fit? if not can I get the Y-pipe off the 2002 and use my converterback system?
Thanks
Old Nov 21, 2008 | 09:43 PM
02StanGT's Avatar
Default RE: 2002 3.8 in a 96
From what I understand, the intake manifolds are different as well (newer one is straight, where the older one is angled). The exhaust manifolds are better, and should fit the stock y-pipe. If for some reason it doesn't you can use the y-pipe from the other car, but you would need to install an O2 bung before the cat. Other than that, I can't think of any sensors that would be different between the two systems.
BandidoLenny
Dec 9, 2009 06:53 PM
JohnCisco
Dec 14, 2008 02:38 PM
rsh3429
Sep 12, 2008 06:22 PM
james26
82-92 V8 Tech
Oct 30, 2006 08:54 PM
LosingStreek86
Feb 17, 2006 07:00 AM
