2000 Chevy camaro
Old 07-14-2017, 11:17 AM
peterpar's Avatar
Another way around this would be replace the original BCM with the BCM from the car that the column came from.
Old 07-14-2017, 11:27 AM
Ejofurrall's Avatar
yeah not sure that's an option because I got it from a guy who had the column for two years before I got it
Old 07-14-2017, 01:04 PM
Thefoodman52's Avatar
Just play roulette with the resistors until the car starts, then never worry about VATS again.
Old 07-14-2017, 02:06 PM
i would get the correct key just in case resistor takes a crab
Old 07-14-2017, 04:43 PM
Ejofurrall's Avatar
Cant the original keys were lost
Old 07-14-2017, 07:03 PM
I believe the BCM's have a Vin code it verifies so swapping that out is not an option. The Vats can be programmed out of the PCM by anyone with HPtune but your security light will come on at some point but the car will still run.
Old 07-14-2017, 08:12 PM
Ejofurrall's Avatar
is there a special cord that I need to plug in the laptop to run the hptune?
Old 07-15-2017, 02:39 AM
sorry, once you figure out the correct key pellet value needed.
Old 07-15-2017, 02:40 AM
if you havent found it yet, this is a good place to get info on the early 4th gens. 4th Gen LT1 F-Body Tech Aids
  #20
Old 07-15-2017, 08:08 PM
Yes and there is a cable and a learning curve as well the software is very expensive. You could get the GM dealer to fix it for less then a seat of Hptune will cost you.
Quick Reply: 2000 Chevy camaro
