2000 camaro won’t start
Old Oct 1, 2017 | 10:45 PM
Gregfis's Avatar
Default 2000 camaro won’t start
i need some thoughts on my 2000 camaro 3.8. I’m having an issue where I turn the igionition to the on position and all my gauges come on the fuel pump cycles and I have complete power. I go to start and I hear a click and lose all power, absolutely nothing works, if I disconnect the battery and connect it Ill have power again and the same cycle repeats itself when I go to start. The battery has a full charge I checked fuses and they are fine so I’m at a lose, any ideas would be greatly appreciated.
Old Oct 2, 2017 | 08:41 PM
Y2K's Avatar
Y2K
Make sure the battery terminals are clean and tight and check the other ends too,a bad ground can do that and so can a bad connection on the positive at the starter.
Old Oct 3, 2017 | 04:31 PM
yes the connection at the starter could be the issue or starter bolts holding it to the engine may be lose.
Old Oct 4, 2017 | 10:44 AM
Everett#2390's Avatar
Good suggestions and mine is cables may be deteriorating due to corrosion.
Nothing smaller than 1/0 AWG.
ChrisB83
May 27, 2016 11:10 AM
Reverend Bull
Oct 6, 2012 12:22 AM
Sheriff420
82-92 V6 Tech
21
May 21, 2011 09:24 PM
adkins
Sep 24, 2010 08:42 PM
chevy_man
Jun 25, 2007 08:56 PM
