2000 Camaro
Old Aug 7, 2012 | 11:13 PM
jb9513's Avatar
Default 2000 Camaro
Hey guys here is the situation. I have a 2000 Camaro and was having issues with the Body Control Module, when i would hit a bump in the road the radio would shut off and the windows would stop working. Did a little research and discovered it could be the BCM so i did the fix to the connections as was givin in the form to fix it. well it fixed the current situation but now i have another problem. The radio will not shut off when i turn the car off and open the door. I have to manually turn the radio on and off each time i get in it the windows will roll down without the key in the ignition and the when i lock the car the alarm is suppose to honk the horn twice to tell me its locked, now what it does is the lights flash and when i click it twice the car will only beep once. I really dont wanna replace the BMC since it costs 300 to get. If anybody has any info as to why its doing this please let me know.
Thanks
Old Aug 7, 2012 | 11:48 PM
BasicConcepts's Avatar
Technical User
check the spots that were resoldered, make sure you dont have any crosses or shorts.
coopdc78
LS Series Tech
Jun 19, 2010 12:28 PM
hermine2000
2010+ V6 Tech
Mar 22, 2010 02:56 PM
TwistedEdge
Oct 2, 2008 02:00 PM
Mx35foxracing
VS
19
Dec 3, 2007 10:19 PM
chevy_man
Jun 25, 2007 08:56 PM
