2 quick questions
Old Apr 24, 2009 | 04:15 AM
AmirGTR's Avatar
Default 2 quick questions
first of all I want best bang for the buck.
So ok my 94 Z28 rides too rough and the previous owner lowered it a little too much for my taste. I want best bang for the buck suspension thats as comfy and quite as it gets. what do i get?
second question. I'm getting my rear end fixed. might as well get better ratios. what ratios do I get? also heard of something called spool. what does it exactly do? would it help the rear end last longer?
Old Apr 24, 2009 | 07:39 AM
whammer3024's Avatar
ROTM Winner
is your car auto or manual?
google the name sam strano and find an email for him...tell him what you want from the suspension and he can tell you exactly what to get as far a shocks and springs
Old Apr 26, 2009 | 07:54 AM
AmirGTR's Avatar
I contacted him but he didn't respond.
Old Apr 26, 2009 | 02:04 PM
YoungDriver's Avatar
For gear ratios:
Higher gear ratios make you accelerate faster, but have a lower top speed. It also lowers gas mileage around town.
Lower gear ratios make you accelerate slower, but have a higher top speed. Usually better gas mileage around town.
If your going as a weekend warrior get high ones, if it's a daily driver use a happy medium.
As for spool, the only time I've heard of spool is on a turbo-charged. Get a lower gear ratio for turbo-charged cars.
Old Apr 26, 2009 | 02:25 PM
For the record, a "lower" gear ratio is a higher number, ie: 4.10 = a lower ratio, for more bottom end. Higher or "taller" gears are smaller numerically.
A spool is where there is no "differential" in the center section. Left and right axles are locked together. It's not something for the street because you'll have a very hard time making turns.
Old Apr 27, 2009 | 02:56 AM
AmirGTR's Avatar
So I guess the the best choice for me is a lower ratio, since I want better fuel economy. 330ft.lbs is plenty to work with, I don't think I'll have a problem accelerating. Worst case scenario would be having to turbocharge the hell out of it.
What about the suspension though? I sometimes go on long trips, I want it to be fairly comfortable.
Old May 17, 2009 | 06:45 AM
AmirGTR's Avatar
So I think I found the answer to my second question.
I'm looking into air suspensions right now. Sounds like a pretty good idea; first of all, I won't have to worry about rubbing the nose against the road each time I get into a parking lot. Second I'll get to lower the car to show it off to my friends. Third, it'll give me great ride comfort, and fourth, it'll give the firmest ride for track. All thanks for the fact that its height and stiffness are adjustable.
...Or so I'm told by this website: http://www.popularhotrodding.com/tec...all/index.html
I would like to know your opinions before I make plans to save up money for this operation. I know the suspension will cost me an arm and a leg, but that would OK if its as good as they say it is, and doesn't cost another arm and a leg to install. I don't wanna saw my ride, I'm just looking for straight up bold-ins. If anyone knows a cheap supplier that'd be also appreciated.
Old May 17, 2009 | 09:24 AM
sam strano is a good guy to deal with. not easy to get ahold of as u have found but worth the trouble. go with 342 gears.
http://www.stranoparts.com/
Old May 17, 2009 | 04:53 PM
brian_rs/ss's Avatar
June '09 ROTM Winner
deffinately eibach pro kit for springs. and for shocks the KYB AGX are probly the best bang for the buck. or if u wanna do some drag racing the QA1 12 way adj. shocks.
and as far as gears go thats totally up to you, especially if you have a 6 spd. but for automatic ide say the 3.55's are a good streetable set.
Grandpaswagon
Jan 9, 2010 04:59 PM
Camaro Man 1999
Jan 28, 2008 10:12 PM
BAN WS6
Nov 19, 2007 06:42 PM
Zzz28sleeper
LS Series Tech
Jun 7, 2007 02:06 PM
Dietz589
Jan 9, 2007 03:58 PM
