1999 motor replacement
I have a cracked block on my 1999 camaro with the 3.8 I found a 1997 3.8 camaro motor that I could buy but I've heard the manifolds need to be changed and the intake off the 1999 but is the motor the same or will I need a new wiring harness or other things
You are posting in the 3rd gen section, you have a 4th generation. If you check out the V6 area in the 4th gen area. You have a lot of option. I put a 2002 3800 in my 96, click on the link in my sig. Project 96 I think I show a side by side pic and I mention the manifolds. You also have the option of getting a much newer 3800 out of a front wheel drive car. They tend to be a lot cheaper and you can find low miles ones pretty easy.
