1999 Camaro headlights not working!! Please HELP!!
Old Aug 30, 2010 | 05:34 PM
sniperSTV's Avatar
Question 1999 Camaro headlights not working!! Please HELP!!
I Bought a 1999 Camaro and the headlights dont work !!! All the other lights work but not the headlights. So I replaced the bulbs,didn't fix it. So I'm looking for the headlight fuses and I can't find them, so if any one knows where the fuses for the headlight are or if it might bet the headlight relay or maybe the headlight switch. Any Advice is Appreciated!! Please let me know. Thank you for your help!!
Old Aug 30, 2010 | 06:35 PM
libertyforall1776's Avatar
Did you see the headlights work before you bought it?
There are fuse boxes under the hood (driver side front) and the driver side dash panel side towards the door.
Old Sep 7, 2010 | 08:07 PM
sniperSTV's Avatar
No, I did not even look, I bought it from my brother-in-law and didn't even think about it, my own stupidity, but its mine now and I need to fix it. I've looked in all the fuse boxes and I can not find a fuse for the headlights. I've replace the relay and all 4 headlight bulbs. My next step was going to replace the headlight switch and see if that will do it. I also found out the A/C Compressor is bad and I have to replace it, but at least I can drive W/ the T-Tops off and give it a major tune up. Anyway Thank you for the advice.
carsearching
Nov 23, 2011 06:15 PM
sebi1990
Oct 19, 2010 08:21 PM
JDTSBLACKSSZ28
Feb 19, 2009 08:47 PM
hackson
Sep 13, 2007 05:41 PM
