1998-2001 ls1
1998-2001 ls1
How's everyone doing? I dont have a camaro yet. I want to get a 98-01 camaro. I tried restoring a mustang and i said F*** this. i want a camaro. So what is the reason for this post?? What are some mods i can do to make it fly. I already found the exhaust i want.
What im looking for is:
Cam
Hood
Computer Chip
Supercharger
Cold air intake
And anything else that would make it fly.
thanks,
jeff
Cam
Hood
Computer Chip
Supercharger
Cold air intake
thanks,
jeff
RE: 1998-2001 ls1
wish i knew where to start. get new ring & pinion i wouldnt go above a 4.56 or even a 4.10 depending if you drive it daily. i recommend between 3.23-3.73. K&N makes good CAI, bigger throttle body,mass airflow sensor, fuel injectors.if you get a 98 switch the intake manifold cause stock is too restrictive. just a couple of ideas
RE: 1998-2001 ls1
why 98-01? is there something wrong with 02s?
what do you want to run? saying "i want it to fly" doesnt really work. are you looking for low 12s? 11s maybe? or full blown race car?
a good heads/cam setup can net 500+ horsepower and land you nicely into the 11s.
the stock gear is 3.42s for manual so he's already in your range, swapping gears and getting any kind of tire means the 10 bolt s on borrowed time.
ORIGINAL: JHL88
RE: 1998-2001 ls1
Don't forget a good set of long tubes and a new Y pipe, bolt ons first, before you do anything internal, or you won't get nearly full potential out of your cam etc. Remeber, if you can't get the air in and the exhaust out, a bigger cam doesn't do much good.
