1997 Camaro Z28 5.7 acceleration problems. Help!
Old 01-21-2011, 03:07 PM
Originally Posted by craby
pete are you saying there is not a cam sensor in the opti on the 97? if so how does it know when to fire the spark?
The opti for a 97 is the same as a 1994.5 and up. Starting in 96, GM put a separate sensor in the (3rd version) timing chain cover for diagnostic purposes. It has nothing directly to do with, and isn't part of the opti.
Old 01-21-2011, 03:10 PM
if you can find a place with a diognostic code reader that would be best, that way if theres a code for the trany in there it will show. check all your plug wires to make sure they are on all the way, also check the coil wire to make sure its on all the way to. i am thinking the motor is misfiring and causing the problem. could be running rich, might be a good idea to pull a couple plugs to see if they are fouled, black, if so that may be the cause of the misfire. if it is the tcc i would think you would have a code for it.
Old 01-22-2011, 03:11 PM
sebi1990's Avatar
I'd check the sparks and wires I had teh same problem i got it fixed by replacing all the ignition coils on my car
Old 02-03-2011, 02:28 PM
ChandlerMotorsports's Avatar
Former Sponsor
Another recommendation for a scan
Old 04-15-2011, 11:17 AM
Hazard29's Avatar
Turns out that fuel pump was starting to crap out, not holding enough PSI.
santa6
10-23-2011 08:12 AM
Hazard29
01-30-2011 03:15 PM
wade79camaro
10-11-2009 01:39 PM
mdawood
03-29-2009 02:31 AM
Baseballchris05
05-06-2007 01:46 AM
Quick Reply: 1997 Camaro Z28 5.7 acceleration problems. Help!
