1996 RS 3.8 v6, ignition system stops working.
Old Mar 28, 2011 | 08:08 AM
osduck5's Avatar
Originally Posted by 1984z28
I might need some assistance with bypassing the starter relay. Unfortunately not that familiar with the gen 4.
http://shbox.com/1/vats_bypass.jpg
4th Gen LT1 F-Body Tech-PassKey/VATS
Old Mar 28, 2011 | 07:15 PM
1984z28's Avatar
Well I got held up at work today so haven't got a chance to bypass the vats yet, I tested the key and it was reading .601 ohms which isn't any where on the list in the resistor list.
Old Mar 28, 2011 | 07:26 PM
3800camaro's Avatar
Do you have a spare key at all?
Old Mar 28, 2011 | 09:44 PM
1984z28's Avatar
Unfortunantly she doesn't have an extra key, guess I'll make a switch with multiple paths to multiple resistor and just hope I get lucky. I have enough to make the first 7 resistor types.
Old Mar 29, 2011 | 11:23 AM
Massey's Avatar
If you try to start the car with the wrong resistor you will have to wait 3 mins or so before you can try again. Unplugging the battery does not work to reset the timer, it just stalls the timer untill it gets power again. GM parts can tell you what key you should have based on the VIN, but you have to show them proof of ownership before they will give you the info.
Massey
Old Mar 29, 2011 | 11:50 AM
3800camaro's Avatar
Ya your best to go to gm and get the info and new key's. Messing around with the vats system can cause future problems.
Old Mar 29, 2011 | 10:40 PM
1984z28's Avatar
Well I figured it out, got the vats bypassed and installed a bypass button you have to hold in when starting the car. So the system still works unless you know about the hidden away button.
Old Mar 29, 2011 | 11:30 PM
1984z28's Avatar
Thanks for all the help guys, you guys really saved me. The experience working on this gen 4 reminded why I always stayed away from them lmao. Kinda makes me miss my 84 z28 never had a problem with her.
Old Mar 29, 2011 | 11:58 PM
3800camaro's Avatar
Haha. Ya these cars have way to much electronic crap for my likings too. I want to get a mid to late 70's just so I don't have to deal with 50 sensors for one little problem.
Old May 31, 2011 | 08:06 AM
  #20
texas_RS's Avatar
if the dash lights goes black when you turn the key over you might have a loose ground wire... mine went to 3 shops before we found out what it was... all that money for such a simple problem
