1995 Camaro 3.4 no fuel pump relay signal
Old Jun 29, 2019 | 11:49 AM
Ndb36's Avatar
Default 1995 Camaro 3.4 no fuel pump relay signal
I have 1995 Camaro with a 3.4 engine.
it was running them died. Fuel pump is good but the relay is not being activated.
there power to relay but not being sent to fule
pumo , any ideas?
Old Jul 1, 2019 | 09:00 AM
try switching one of the other relays with the fuel pump one and see if it works
Old Jul 1, 2019 | 11:41 AM
Ndb36's Avatar
Already swapped and bought new relay , the relay is not getting signal to turn on or activate
Old Jul 1, 2019 | 01:35 PM
That is how the security system keeps the car from starting. Is you security light on? Could be a fuse or a broken wire you will need to crack a manual, I do not remember this being a common issue.
Old Jul 1, 2019 | 03:48 PM
Ndb36's Avatar
Been thru wiring , no issues found yet.
security light doesn’t stay on .
Old Jul 2, 2019 | 11:15 AM
have you tried the primer jumper wire to see if fuel pump comes on. http://shbox.com/1/fuel_pump_prime.jpg
Old Jul 2, 2019 | 11:31 AM
Ndb36's Avatar
Yes I have , it’s does engage the pump
Old Jul 6, 2019 | 11:14 PM
pcm should be sending an enable signal have a look here and see if it can help. http://shbox.com/1/pass_key.jpg
Old Jul 7, 2019 | 06:18 PM
peterpar's Avatar
You're going to need to check for voltage and a ground between the dark green/white (465 at relay term #85) and the black/white (451 at relay term #86) wires at the relay when the ignition switch is turn to the on position. This is the power supply that energizes the relay coil to close the relay contact. If the PCM contact is faulty or the dark green wire is broken between the PCM and relay coil or the black/white wire between the ground source and the relay could cause what you're describing. The attached trouble shooting chart may help with checking the system.
Old Jul 7, 2019 | 06:38 PM
Ndb36's Avatar
Thanks I will give that a try
