02 SS full boltons .. what to expect?
Old Feb 23, 2009 | 07:59 AM
KuwaitCamaroSS's Avatar
Smile 02 SS full boltons .. what to expect?
got a 02 camaro ss taking it to the dyno
gotslp headers and intake and all that
and cam but dunno the lift of its rough ..
what kinda numbers should i be expecting?
Old Feb 23, 2009 | 08:14 AM
robmnrd's Avatar
Not knowing the specs on the cam, it's hard to make an accurate guess. But I'd say that as long as it isn't too much cam for the stock heads, you could be around the 400rwhp mark. Maybe a little bit higher.
Old Feb 23, 2009 | 08:39 AM
SpecterGT260's Avatar
Ninja Administrator
"over-camming" is something that happens when you meet or exceed head limits. so if the heads flow a given cfm at a given rpm, they will make the appropriate power. stock heads usually start to run out of steam around 400rwhp regardless of what cam is put in there, they can go a little higher, but it gets tougher. the downside is you dont make as much high range power as you could but you are still sacrificing all your low end torque. this is why overcamming is a problem.
wed have to know what cam is in there. 400rwhp is a good mark for a larger cam. 340-350rwhp is about right for bolton only. depending on the size of his cam id say hes somewhere in between lol
Old Feb 23, 2009 | 09:01 AM
robmnrd's Avatar
Yes, telling him a range is a safe bet! haha
OP, you're between 0 and 1000 hp.
halfcoffman
Dec 11, 2007 10:51 PM
prevarications
Jun 10, 2007 10:56 AM
00camaro00
LS Series Tech
Feb 11, 2007 12:01 PM
in_vein101
Oct 9, 2006 09:52 PM
mrmagoo568
Sep 29, 2006 06:45 AM
