01 SS P0412, 410 and 418 codes
Old Jun 10, 2014 | 09:44 PM
FSTKMARO's Avatar
Default 01 SS P0412, 410 and 418 codes
Hi all, for a couple of months my car has had the SES light on. Pulling the codes results in the codes above. Searching through the forums I could not find more than the typical pump answer. Anyways, I confirmed that the AIR pump works. I checked the fuse and replaced the relay to no avail. The pump will not start by itself. I cleared the codes but do not hear the pump coming on. I wonder what else could be. I know that there are two check valves actuated by vacuum but I can barely reach them. I wonder if anyone has had to deal with this problem and how it may have been fixed.
An alternative would be to tune out the AIR system test. Is there a way to do this myself?
thanks in advance.
Old Jun 11, 2014 | 08:49 AM
sounds like a wiring or harness connector issue.
Old Jun 12, 2014 | 06:06 AM
FSTKMARO's Avatar
Hi Crab y, thanks for the response, that's what I thought but not having a scanner that can command the test at will, makes it a bit difficult to troubleshoot. I know the wiring to the relay is fine.
Old Jun 12, 2014 | 08:50 AM
solomon will send you the stuff needed to tune. costs a few bucks.
Old Jun 13, 2014 | 10:30 AM
FSTKMARO's Avatar
Hi crab y, h o w do I get a hold of them?
Old Jun 13, 2014 | 12:22 PM
sorry i thought i put the link up there LT1 PCM Tuning - Welcome!
arodrig
Nov 20, 2010 02:43 PM
samtron
Jun 29, 2010 09:48 PM
rwing7486
Oct 18, 2009 03:04 PM
muscleman
Sep 4, 2007 11:00 AM
94Red
Aug 28, 2007 12:53 AM
