01 camaro smells like rotten eggs
Old Nov 13, 2011 | 01:09 PM
01ssls1's Avatar
Default 01 camaro smells like rotten eggs
My car suddenly tthrough two codes saying both downstream o2 sensors are out. Why does it smell like rotten eggs? Is it the o2s or the cats?
Old Nov 13, 2011 | 03:30 PM
BasicConcepts's Avatar
Technical User
The cats are bad
Old Nov 13, 2011 | 10:10 PM
auto's Avatar
i was pushing the car hard the other night alot of stops and hard take offs, when i pulled in at home was smelling the rotting eggs, but dont normally smell them, could it mean the cats are bad too or is it just because i was pushing it?
Old Nov 13, 2011 | 10:41 PM
The exhaust smelling like rotten eggs can be normal, without it being any problem with the cat. Sometimes the brand of gas, or the octane you're using affects the exhaust to smell like that. If you're getting the smell regularly, switch stations, or move up to the next octane level. It could take a few tanks of gas to clear out the cat, and the smell.
In the OP's case however, the fact that he got a downstream oxy sensors error, the cat(s) would be suspect.
Old Nov 13, 2011 | 11:29 PM
charlie94's Avatar
How about sulfating battery
never mind i missed the codes
Old Nov 14, 2011 | 09:35 AM
01ssls1's Avatar
So since the codes ssays o2 sensors its probably the cats? So I shouldn't replace the sensors?
Old Nov 14, 2011 | 11:07 AM
libertyforall1776's Avatar
Rotten eggs smell is from sulfur -- you likely need cats -- how many miles on the car? The rear sensors measure the efficiency of the cats, and that's about all they do...
Old Nov 14, 2011 | 02:47 PM
auto's Avatar
107k miles
Old Nov 14, 2011 | 08:21 PM
JGuy07's Avatar
Replace the CATS, or just gut if you don't need them for emissions.
Navy inbound to sweep out the pirates!!
Old Nov 14, 2011 | 09:41 PM
auto's Avatar
sorry didnt mean to hi jack, just figured we have similar if not same issue
