'00 Security light
Old Dec 26, 2010 | 09:12 PM
NovaBrad's Avatar
Default '00 Security light
about 3 days ago I went out to start my car. everything would turn on and function as normal, but when i went to turn it over, nothing happened. I noticed my security light was on and opened the manual. The manual (as well as many of the other threads) said that it was probably because my key was dirty/worn out. So I cleaned my key, and tried it again but nothing happened. It's really hit or miss if it decides to turn over or not, sometimes it does, sometimes it doesn't. I plugged it in and no codes came up saying that something was wrong.
Anyone have a clue why this is happening? I would try my other key, but it is at the opposite end of the state, and I'm not completely convinced that it is the key that is causing the problem. I also notice that the alarm light flashes much quicker than normal when I open the door.
Old Dec 26, 2010 | 10:11 PM
osduck5's Avatar
It could be the chip in the key is going bad or has gone bad. If you have an ohm meter, you can ohm out the chip to see if you get a reading. It could also be the lock cylinder itself.
We had a new key made and it solved our problem.
Check out this link for troubleshooting the VATS system.
http://shbox.com/1/pass_key.html
Old Dec 27, 2010 | 10:19 PM
NovaBrad's Avatar
Well i got the other key, and it didnt work. Taking it to a mechanic tomorrow, any suggestions on what else it could possibly be? and if so, how to fix it?
Old Dec 29, 2010 | 10:33 PM
NovaBrad's Avatar
So should I have them bypass the system or replace the ignition switch?
Socom
Nov 9, 2013 01:41 PM
canomjm1a1
Jul 11, 2013 04:18 PM
JordanN
Jan 8, 2010 10:17 AM
ranger4620
Apr 30, 2007 02:30 PM
Mr. White
Feb 28, 2006 09:06 PM
