rims wont fit
Old Feb 11, 2006 | 02:22 PM
camaroobsession's Avatar
Default rims wont fit
i have a 92 rs but my friend gace me his 4th gen ss rims but there to wide i was wondering if anyone knew the easiest way to make them fit thanks
Old Feb 12, 2006 | 02:19 AM
v8chvyguy's Avatar
Default RE: rims wont fit
The width is'nt the issue, the offset is. the fourth gens use what I call a front wheel drive offset where the hub flang is very close to the outside of the rim. your 92 uses a rear wheel drive offset which locates the hub flang closer to the rims centerline.I highly doubt you can make them fit and be safe to drive. No one manufactures a spacer large enough to give you the backspacing you need because it's not safe.
luciora
Apr 12, 2010 08:18 PM
metalmuskie
May 2, 2009 03:00 PM
94 z28
16
Feb 24, 2008 02:31 AM
90blackrs
Nov 25, 2007 11:20 AM
Abyliks
Mar 5, 2007 09:54 PM
