how big
Old Aug 4, 2006 | 11:30 PM
camaroobsession's Avatar
Default how big
will 15x10" rims work on my 92 rs
Old Aug 5, 2006 | 12:13 AM
SickSickSick's Avatar
Default RE: how big
as long as they have 4 1/2 inch back spacing or less. backspacing is distance from the outside lip to the lug mounting surface on the backside of the rim. you can lay the wheel on the ground face down and lay a straight edge across the rim measure the distance between the straight edge and the mounting surface. that will give you the back spacing. sick
