wont start
Old Dec 29, 2009 | 07:41 PM
Dr.Bumble's Avatar
Default wont start
hi i got a 84 camaro with the 305 it ran when i bought it but it had alot of problems i replaced all the belts plugs new distributor plug wires, fuel filter battery and now it wont start i have the fireing order right i am 100% sure about that ive checked multiple times. when i replaced the plugs 2 of the plugs werent hooked up the wires were just loosly put on so those two plugs werent active so i hooked em up with new plugs and wires and now it wont start i gotta get this car back on the road its what i got to get to work..
thanks
Old Dec 29, 2009 | 08:42 PM
microkid's Avatar
March 2011 ROTM
Technical User
is the engine turning over? is it getting fuel? if you changed the filter, the line may have run dry. is it tbi or carb? it might be starved of fuel and if its carbed, it will take a while until the pump primes itself again. try a small shot of ether and see if it runs.
Old Dec 30, 2009 | 08:19 PM
Dr.Bumble's Avatar
it turns over and i took the filter and cover off and when i turned it over it would spout gas up out of the carb so its getting fuel
Old Dec 30, 2009 | 08:32 PM
Are you getting a good spark??
Old Dec 31, 2009 | 07:21 PM
Dr.Bumble's Avatar
yup sparks fine. im just out of ideas
Old Dec 31, 2009 | 07:28 PM
Are you saying gas is spouting out of the carb as you're cranking the engine over to start it?
Old Jan 3, 2010 | 04:54 PM
Dr.Bumble's Avatar
yes it spouts probly a foot and a half out the carb. but it ran before i change the plugs. as soon as i changed em it wouldnt start.
Slundy12
Dec 11, 2011 07:57 PM
Luz Hernandez
Feb 26, 2011 09:17 PM
mjstempky
Feb 19, 2011 01:17 PM
jpkz94
Jan 21, 2011 01:47 PM
89Rally
May 3, 2007 01:49 AM
