WHat combo can I run?
Old Oct 21, 2008 | 04:45 PM
Phatt_daddy's Avatar
Default WHat combo can I run?
Ok so I am familiar with the whole subframe connectors on a mustang and I also have quite a few camaro owning friends and realize that basically the same thing needs to be done in order to keep them from twisting as well. With that in mind what is the best combo to run in a 3rd gen? Keep in mind I want to run either a 5 or 6 spd man. tranny.
Also do these cars use a cable clutch or a hyd.?
Thanks,
Nate
Old Oct 21, 2008 | 05:29 PM
irocktheIROC's Avatar
Default RE: WHat combo can I run?
are you asking wheter you should run 5 or 6spd with subframe connectors???? idk, go 6spd, hydro clutch with a wilwood adjustable slave cylinder
Old Oct 21, 2008 | 05:32 PM
SpecterGT260's Avatar
Ninja Administrator
i dont think you will get a t56 mounted to that motor easily....
Old Oct 21, 2008 | 07:00 PM
MadMikeZ28's Avatar
ORIGINAL: SpecterGT260
There are kits for it. There is not much money can not fix.
Old Oct 21, 2008 | 07:05 PM
Ninja Administrator
i figured. I would just go with the 5speed though for ease. unless he thinks he will be breaking it
Old Oct 21, 2008 | 09:41 PM
What I am asking is this.................. For a 3rd gen camaro what is the best engine with the most hp that I can run for a 16 yr old and run either a 5spd or a 6 spd? ie 305, 350, 327, 383, sb427, bb what are my options. I am familiar with the mustang engine bay but not the camaro. Like I know that I can put a bb460into a stang and it be streetable but what about the camaros?
Old Oct 21, 2008 | 09:58 PM
DO NOT PUT A BB, you can beef up a sb and weigh about 400lbs less, do not, do not get a bb
Old Oct 21, 2008 | 09:59 PM
and you are answereing your own question, just put a big *** engine with alot of hp in front of a 5spd. I.E. 383 TPI, and a T5
Ace of Spades
Mar 26, 2012 10:39 PM
Ceelo912
Jul 31, 2010 09:46 PM
JHL88
Aug 2, 2007 03:30 PM
1983camaro
Jul 25, 2007 07:19 PM
Nasty Z28
Mar 9, 2007 11:51 PM
