TPI running too rich
Old Apr 7, 2007 | 05:20 PM
  #21
Shmack2004's Avatar
Default RE: TPI running too rich
wheres the 1 for the pcm?
Old Apr 7, 2007 | 10:46 PM
  #22
microkid's Avatar
March 2011 ROTM
Technical User
+2
i took out a sensor to hook up my gauges, but i dont know if i took out the right one or not!
Old Apr 9, 2007 | 06:07 PM
  #23
coprunr's Avatar
there should be one in the side of the head between the exhaust ports, a single wire sensor that is for the gauge. and there should be one in the intake somewhere , that's the one for the PCM...if memory serves me correct it is a 3 wire .....but it may be two...i can't remember exactly....
Old Apr 10, 2007 | 09:54 PM
  #24
Shmack2004's Avatar
so that could cause my problem?
Old Apr 10, 2007 | 11:40 PM
  #25
coprunr's Avatar
yes, when the PCM temp sensor fails they usually read -40 degrees and if that's the case it will run okay when the engine is cold...but get worse and worse as the engine warms up, also after a heat soak it will run really bad (after you have drivin it and got to operating temp. then shut off for a few minutes) , the engine actually gets hotter right after you shut it off becasue the coolant is not flowing and just heats up
Old Apr 11, 2007 | 12:13 AM
  #26
microkid's Avatar
March 2011 ROTM
Technical User
my car prefers hot starts to cold starts, but me and him have the same issue.
Old Apr 11, 2007 | 07:12 PM
  #27
Shmack2004's Avatar
so i replace it is there also a way to trick the pcm into thinking its running hotter than it really is?
libertyforall1776
Jan 27, 2011 12:55 PM
mxskater56
Jun 24, 2009 04:28 PM
orlando_trudeau@yahoo.com
Jun 16, 2009 12:35 PM
akbyrner92
May 15, 2008 04:34 PM
atlanta2008
67-69 V8 Tech
Sep 13, 2007 06:24 AM
