toss up between a 350 or 305 to build
Old Apr 16, 2008 | 01:59 AM
caldwell91camaro's Avatar
Default toss up between a 350 or 305 to build
I need a little help just got a 91 camaro rs with a 305 Tbi and would like to build some thing with more power the stock 305 just don't do it don't know what to do build it or go to a 350 would like some ideas don't know if i sould go to carb or stay with the Tbi would like something cheap for now
Old Apr 16, 2008 | 06:11 AM
Default RE: toss up between a 350 or 305 to build
You need to look at your emission laws. 300 HP and down the 305 will do. The base casting is weak so depending on its condition you might want to think twice about adding any power to engine that is not fresh. Back when these car where new we put a lot of cranks in the 305 under warranty. I doubt they got better with age. The 350's hold up a lot better.
Old Apr 17, 2008 | 12:57 AM
thanks gorn i think i would like to put the 350 in but didn't know how hard it would be to do and didn't know if i sould go back to tbi or not if you have any ideas that would help. But for the emission i don't have where I'm from a least not yet
Old Apr 18, 2008 | 06:58 PM
1badz28's Avatar
do the 350 it open's you up to a lot of performance mod's that the 305 won't handle good luck
Old Apr 19, 2008 | 12:20 AM
thanks 1badz28 i think i will do that but dont know if i sould go to carb or stay with the tbi or not what is better and easier to put in
Old Apr 19, 2008 | 04:44 AM
1badz28's Avatar
if emission's ain't a problem in your area i'd go carb lot easier and many size's to choose from for your setup
Old Apr 19, 2008 | 04:41 PM
do you know how hard it would be to put the 350 carb in and take out the 305 tbi and eliminate all the junk wires and what all ill need to do it i know i need to take the fuel pump out of the tank and put it on the block well any ideas it would help and thanks
clay95z28
Oct 22, 2012 08:11 AM
MN79Camaro
Mar 8, 2012 08:32 PM
nine-six-zee28
Dec 29, 2010 12:17 PM
Unit94Z28
Feb 2, 2010 08:01 AM
outta_control_z28
Sep 12, 2009 03:35 AM
