tbi build up problems
Old Jan 30, 2008 | 02:20 AM
apsolus's Avatar
Default tbi build up problems
i bought a 91 RS with a 350 TBIsilverado motor swap. after installing and altering everything on the engine, i replaced the entire fuel system, new pump, filter, injectors, 2in bore throttle body, adj fuel press regulator, bored out my stock intake manifold and bored it to 2in bore, added iron eagle heads with 2.02 intake and 1.60 exhaust, swapped the cam with a computer freindly TBI cam, and got a custom chip made with all the new infoi got off my laptop, it makes no power. the dyno read 194 hp!!! And instead of a gradual raise in horsepower over the rpm range, i made absolutely no power until 5500rpmwhere it made the 194!! thegraphlooked like one of those earthquake charts!! thats almost less than stock! stock 350's made 210 at the flywheel. sence then ive had 2 other chips made which made no difference. is there a problem with a sensor or something? there are no check engine soon lights onor anything. maybe its the wiring harness? please any help will be very appretiated!!
mp734
Nov 6, 2013 11:54 AM
David RS
Oct 15, 2009 05:03 PM
69camaroaddict
Oct 3, 2009 08:54 PM
IZZY1967RS
Jun 19, 2008 10:29 PM
jdubs1813
Nov 12, 2007 04:16 PM
