Speedometer, Please Help!!!
i had a bulb go out behind my speedometer and i had to remove it in order to replace it. i also had to remove the needle. now my question is where is 0 mph at? is it all the way against the trip reset peg or is it midway between the peg and 5 mph, there is a little white dot there. please some one go look at their 87 and tell me where it is. thanks a million.
It is the 145 MPH Speedometer. but as far as where 0 MPH is, they may be the same. im really not sure about that one. but look anyways and let me know. thanks for helping me out.
I know it's too late now, but you should have pulled the gauge cluster out as a whole to simply replace the bulbs from the back side. As you've found out, doing it the way you did opened up a needless can of worms.
Hey thanks man. i looked at mine again and that is exactly where it is, about 1/8" to the left of the small white dot. when i put it back i set the needle right on the dot. but after i drove it the needle "settled" at the exact spot you told me. oh by the way i know that is the right spot, i drove past one of those police "check your speed" things on the side of the road, and its right on the money. again thanks for helping me out.
