Spark Plugs
Old May 4, 2009 | 08:30 PM
IROC-ON's Avatar
Default Spark Plugs
What type of plugs do you guys run? I have had good luck on the Autolite 26 that i have in my 87 Iroc. Anybody know of anything better? its getting close for me to change mine.
ps- i have accel 8.8 wires and an accel super coil, if this matters.
Old May 7, 2009 | 03:37 AM
MitchellDeMoor's Avatar
Well I have been saving these really amazing ones that I have for when I get my motor built up. They are an NGK and are supposed to be the beast you can get they are kind of old though I bought them of an old school guy at his speed shop. When I get home from school today I will get you the part number allthough you may have a hard time finding them and might have to check eBay. Right now I don't really have a very special motor and I am not racing currently so I am just running ACDelco plugs gapped at 0.035.
Old May 7, 2009 | 08:16 AM
IROC-ON's Avatar
thank you, they sound very interesting, i would like more info.
Old May 8, 2009 | 11:56 AM
Hey man
Try these they are a really good performance plug.
Resistor Type V-Power North American #4762.
They come in packs of 4 so you will need to buy 2 boxes.
It is an older set of plugs so you may need to do a cross reference but I am not sure.
Good Luck!
Old May 8, 2009 | 03:41 PM
Saint Ebony's Avatar
Third Generation Moderator
March 2010 ROTM
They came out of the factory with AC Delco R43TS, and mine have been replaced with the same; I've had no problems.
Mind you, my engine is bone stock anyway.
Old May 8, 2009 | 03:49 PM
IROC-ON's Avatar
hey, thanks guys.
Old May 9, 2009 | 01:50 AM
Originally Posted by IROC-ON
hey, thanks guys.
No problem man. If you ever need any part numbers let me know I have had just about every speed part on a Camaro. If you just wan't a regular plug here are an ACDelco one 19157995.
Old May 20, 2009 | 01:52 PM
djs383's Avatar
Theres really nothing special about NGK, thats all I've run on my race bikes for 5 years now. They are the delco of japan and typically specialize in small bore motors like the 50-250CC 2ST or the 250/450F 4stroke mx motors. For the demand of a stock ignition system, the delco or autolites are just fine. Beware of using special plugs if you're going to run an MSD setup
Old May 20, 2009 | 02:53 PM
sammycamrestorer's Avatar
The NGK and Bosch platnium 4's are expensive plugs that have great spark capabilities for imports. As a novice I used the NGK plugs and my 350 totally took a dump on me as far as power is concerned. I was yelled at from many peps. Professional race car motor builders. I put back in a new set of ACDelco's and never had a problem and lost anymore power. I always use Delco plugs on my vettes and camaros. I have a simple method of tune up that never goes wrong and holds up with other performers. Delco plugs on msd wires and distributor. 4 quarts of good ole Havoline 10-30 oil backed by 1 quart of rislone engine treatment. and a K & N reusable oil filter. You can't go wrong. I have built many 350's and the first elements after installation I use is the above formula. I have had motors last 200,000 miles. It's my own experiment I've come up with. When I was a novice mechanic I was all about the most expensive parts, the super plugs the royal purple synthetic oil. All crap! I had a fresh crate 350 from the general I installed a few years back in a berlinetta and I used royal purple and all that crap. 50,000 miles later I was pulling the motor out and rebuilding it. I don't abuse my cars. I treat them respectfully. I only drag a few. But, of coarse this only me talking for me. You can do what ever you wish. Just remember. If you think your girlfriend or wife is high maintance. Buy a vette or a camaro with a few miles on it. Or even modify it. You have no idea what tempermental is until then! LOL!
VALHAR
Jul 22, 2013 02:14 PM
jeu510
67-69 V8 Tech
Oct 26, 2012 04:21 PM
Z28Freak
Apr 19, 2011 01:02 PM
sebi1990
Oct 10, 2010 10:24 PM
