RPM surging
Old May 7, 2013 | 11:27 AM
Originally Posted by slick's camaro
Are you really trying to help?? Every post I see from you your selling a d** chip. I swapped my 2.8 to a 383 and it runs fine. Guess I still need a chip too huh?
I've been noticing the same thing recently, thought it was just me. Birdman, if you want to help, then by all means help. But kindly refrain from subtly working your chip burning service into most every solution you come up with.
Old May 8, 2013 | 07:48 AM
birdman11's Avatar
Don't you know that almost every change you make to a fuel injected car requires a new chip burned? Especially engine swaps!
Old May 8, 2013 | 10:25 AM
slick's camaro's Avatar
Really?? Please do explain your theory.
Old May 9, 2013 | 09:26 AM
birdman11's Avatar
The Prom Tuning Guide Book and FAQ: Common Questions and Answers - Third Generation F-Body Message Boards
Read that.
Old May 10, 2013 | 06:17 AM
microkid's Avatar
March 2011 ROTM
Technical User
he is correct, especially with older efi. they can only compensate correctly for atmospheric changes on a stock engine. will it run fine with intake and exhaust, yes. will it run the best, no. especially not with a lot of work done
back on subject, how bad is the surge? base on what you said, im assuming its tpi. what is the rpm range that it is going up to and down to? have you tried resetting the iac motor or doing any idle adjustment?
67SuperSport
67-69 V8 Tech
Jul 20, 2015 11:41 PM
disipiot
Jun 3, 2011 03:03 PM
96LT1
Jul 8, 2010 08:51 AM
wils5150
Jun 23, 2010 04:18 PM
gtodave05
82-92 V8 Tech
Dec 3, 2006 11:55 PM
