overheating while sitting still
i've been having this problem for close to a year now. i have a 305 v8 and whenever my car sits for 5 minutes at running temp it will then start to heat up and run bad. my fluid level is good and the thermostat was just changed 2 months ago.
Running Temperature on my 89 is 220 F. In winter it never gets over 160 really, and I have a thermostat that opens completely at 175. It used to overheat bad, but a mix of a new therm. and changing it so that the fans come on at 160 also helps keep it at 220-230 when I'm sitting in traffic on a hot Phoenix Summer day.
My IROC is also a 305. Check to see at what temp the fans come on. Also, I did replace my water pump, though it wasn't bad. I had the top end of the motor off and took the safe route to replace it.
