Overheating problem
Old May 24, 2012 | 02:23 PM
Goose6's Avatar
Default Overheating problem
My car, 92 RS 305 TBI, is overheating even on short trips. There's no white smoke indicating intake leak. I have a dual core radiator, a fan with double the cfm capacity as stock, and a high flow water pump. The water pump works fine, the thermostat works as well. The fan comes on when it's supposed to so that tells me that the cooling fan switch is functioning as well. The air dam is in place and fairly new.
Any suggestions on where to start/what to check for or replace?
Thanks
Old Jun 10, 2012 | 07:03 PM
Paul86iroc's Avatar
Try the head gaskets? You might have a cracked one.
Old Jul 1, 2012 | 09:47 PM
ChevhedZ28's Avatar
Pressure test the cooling system sounds a lot like a head gasket to me too.
Goose6
May 29, 2012 04:50 PM
tedbell
Feb 15, 2012 07:20 PM
KoldSteal1
Oct 13, 2010 10:24 AM
glue maker
Mar 13, 2010 11:29 AM
funnyha_ha
Aug 16, 2007 10:18 PM
