Overheating problem
Old Aug 15, 2007 | 05:39 PM
funnyha_ha's Avatar
Default Overheating problem
i have a 94 camaro with a 3.4L ive replaced everything in the coolant system and it still overheats..some one told me there are air bleed vavles on the block that i have to open in order to pull coolant back into the block.Is this true if so where are the vavles?Also when it is running an i hav the radiator cap off there is air bubbles coming out of the radiator and so kind of steam is coming out what is that someone told me a have a blow headgasket???
Old Aug 15, 2007 | 05:56 PM
LT1RUNNER's Avatar
Default RE: Overheating problem
Read the thread titled "BAD HEAD" and that may help you. It's regarding the same thing you are asking.
Old Aug 16, 2007 | 10:18 PM
02StanGT's Avatar
What is the engine temperature when you see the air bubbles? If it happens also when it's cold, then yes you possibly have a blown head gasket. If it just happens when it's hot, then it's normal. Water BOILS (turns to steam which is the causes bubbling) at 212 degrees Farenheit at atmospheric pressure. With the cap off the coolant in the radiator is at atmospheric pressure.
Goose6
May 29, 2012 04:50 PM
tedbell
Feb 15, 2012 07:20 PM
KoldSteal1
Oct 13, 2010 10:24 AM
glue maker
Mar 13, 2010 11:29 AM
Attila
Jul 22, 2007 09:34 PM
