over heating sorta
RE: over heating sorta
Check your lower valance(I think that's the right term), it may also be called an air deflector. It's the plastic piece right under your radiator. http://www.ecklerscamaro.com/product...dept%5Fid=1249this is the one that i put on my camaro, fixed the same problem right away. GM should still produce it for your bird.
At highway speed it would be an airflow problem, unless the same problem happens when the engine does the same amount of work at a lower speed.
There is an excellent thread on overheating
https://camaroforums.com/m_88753/tm.htm
ok so you said it starts to redline and gets hot i hope u mean the temp gauge is and not the rpms? but i had a camaro that dod the same thing pver 60 and it was the grill, it was aftermarket and was stopping air flow. try running the fan inside your car it should help to keep it cool
xcorat
08-01-2014 10:39 AM
