Noob engine question
Old Aug 22, 2009 | 06:25 PM
TigerRP's Avatar
Default Noob engine question
I have a used Z28 1987 with 71,000 miles. It runs very well. The people I bought it off of only put 6000 miles on it the last 10 years. It runs well and is very strong. However, on startup I get a puff of smoke.
Not every time - the smoke is blue. Engine is not using any oil that I can tell and the gas mileage hasn't been horrible.
Thoughts? Should I be worried?
Old Aug 22, 2009 | 06:34 PM
Saint_Ali's Avatar
blue smoke is a sign of burning oil
Old Aug 22, 2009 | 07:35 PM
smoke at startup only is usually valve guides or seals. check intake gasket to. mine was so lose the oil was leaking in the intake and getting sucked into the cylinder.
Old Aug 23, 2009 | 07:32 AM
blackz87's Avatar
If you only have the smoke on start up after the car set for period of time, I agree it is the valve seal guides leaking (small amounts) oil into the cylinders (not all of them). It is a common problem with SBC engines and you can ignore it until the leaks start affecting oil useage, then it will require replacement of the seals.
Old Aug 23, 2009 | 01:02 PM
microkid's Avatar
March 2011 ROTM
Technical User
yes, valve guide seals. just about every sbc and its variants have that issue. its nothing to be worried about
Old Aug 23, 2009 | 11:04 PM
Y2K's Avatar
Y2K
Yup,not too hard to replace them should you want to.
Jeepin
Sep 6, 2012 06:06 PM
Mitshiko
Dec 7, 2008 03:14 PM
yazan84
May 12, 2008 11:41 PM
silverbullet02
Nov 26, 2007 01:57 PM
Attila
Jul 18, 2007 01:50 AM
