Newbi question duh!!
Old Apr 15, 2009 | 08:40 PM
tipatalon's Avatar
Default Newbi question duh!!
i'm new to v8 world and have a little question on my camaro engine. Is this a 350 or a 305 ci Name:  a7.jpg
Size:  75.8 KB. , i know this seems stupid like question but i'm wondering if the engine was swap in the past by the other guy, thanks
Old Apr 15, 2009 | 09:09 PM
more info. yr and model? should be a number on the motor block that you would reference in a repair manule. there may be a sticky for it on this site. not centerbolt so should be pre 87. other than that there is almost no way to tell a sb chev 265 from a 350 just from a picture like this.
Old Apr 16, 2009 | 05:31 AM
blackz87's Avatar
Well it is not the stock Factory motor. Anything with your info is just a guess and the only sure thing it is not stock.
Old Apr 21, 2009 | 06:14 PM
Michael Snyder's Avatar
just a really stupid guess.... but i am going to say it is a 305. i dont think any 3rd gen camaros had 350's from the factory until 1985 and that one came with TPI only....not a carb. since the engine lift out tab is still on the front drivers side on top of the manifold i am guessing it in the stock intake at least. (otherwise i would have taken it off and chucked it in favor of a carb lifting plate when i took it out to paint the engine that sickly ford blue!) and i cant imagine swapping in another carb based 350 from another early 80's (pre center bolt head) chevy (imapalla truck, or other) as none of them were really any better than the 305 in the camaro. .
again. just a guess based on almost nothing.....
Old Apr 22, 2009 | 04:50 AM
adirtypoostick's Avatar
From: IN, or hell whichever, wait, its too cold to be hell
I dont believe that it is the original motor. It has the piece for attaching a hoist beside the valve covers. you would have to run the casting number to know what it is for sure. they are located on the back of the motor behind the valve cover drivers side.
Old Apr 22, 2009 | 08:47 AM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
There are a few links. I have a first gen so naturaly I put the really good links in the first gen section... I guess i should share the wealth huh. Here you go...
https://camaroforums.com/forum/67-69-general-43/trim-tag-stuff-engine-block-numbers-14209/
Frg8861
Feb 8, 2013 08:32 AM
jiterbug
Apr 24, 2012 11:29 AM
Scotty69
Mar 7, 2012 04:49 AM
1981 camaro brandon
Jun 2, 2010 10:04 PM
tipatalon
Apr 18, 2009 06:50 AM
