New to the forum an have a problem
Hi, Im new here and have a problem with my new (to me) 1991 Camaro.
It have a weird idling problem. The exhaust smell really rich. It will start fine, but it might randomly die just idling. After giving it some gas driving around, sometimes it will die as soon as i let of the gas. It sometimes will sputter and sound like its try to run, and then die
Thanks for any ones help it would be greatly apreceated
Has the car ever been treated to a tune up? I also have a 91 with the 305. It had a sputtery, jerky idle, but it didn't have stalling issues. I replaced the plugs, wires, cap & rotor. I was curious about the cause, so I tested the engine after replacing each component. The engine didn't smooth out until I replaced the cap & rotor. Your problemscould be from one of many other different things...clogged fuel filter, fuel pump on it's way out, bad pressure regulator.... If it looks like it's never received an ignition tune up, then that and a new fuel filter to start with certainly won't be a waste of time or money.
Dbl6gun
07-07-2015 08:29 PM
