Need help to I.D. HEI distributor
I was going through my storage shelf when I came across an older HEI distributor that I am not familiar with. It uses the same cap and rotor as the mid 70s-early 80s one wire hook up for chevy small blocks as well as big blocks but has 4 extra wires that comes out of the housing. The ignition module also has 5 terminals instead of the 4 terminal style that I'm familiar with. I'm trying to find out what year this small block distributor is from so I can look up the wiring diagram and do a bench test on it to see if it works. The 4 extra wires are blk/brown/white/green. Any responses is greatly appreciated.
Thanks Uncle Bill, I took a closer look and found it like you said. I'll dig around for an older style ignition module and convert it to fit my 80 Pick up.
i have built a mild 350 for my 84 caprice classic wagom and i am pretty good with wireing i am eliminating all emitions and other useless stuff under the hood including wires need to kno what the extra dist wires are for
