need help
Old Feb 8, 2012 | 01:38 PM
dmurray1990's Avatar
Default need help
so i decided to trash my 305 and put a 350 in it just looking for some opinions on what i should do engine and suspension its a stock 1991 camaro rs
Old Feb 11, 2012 | 11:31 PM
Berlinetta's Avatar
If your suspension is not bad I wouldnt change anything, and with the engine do you want build sheets? What do you want, street demon, track racer, decent on gas? Tell us everything you expect.
Old Feb 12, 2012 | 12:38 PM
I'm looking for some good performance the 350 I'm buying is missing a piston so I'm replacing all the pistons
Old Feb 13, 2012 | 07:41 PM
Berlinetta's Avatar
How much are you willing to spend?
Are you planning for N2O or charging the vehicle?
What is good performance to you?
(In my mind decent performance is around 350hp for a 350sbc)
Old Feb 13, 2012 | 09:21 PM
torque_is_good's Avatar
inquiring minds want to know
why is the engine missing a piston?
Old Feb 14, 2012 | 08:42 AM
The piston was removed b excuse the guy who has it was gonna replace them but he had got rid of the car and has the engine in his garage its from a trusted friending of the family engine is clean and everything and it was running when he took it out and as far as n20 most likely not and maybe charging it way later down the road rite now I'm just looking for some peoples opinions on what to do something thsts not crazy expensive but not cheap either
Old Feb 14, 2012 | 01:20 PM
I'm sorry but I'm still stuck here
you don't change pistons just for shifts and giggles
why is it missing a piston ?
you want to believe that it's all just hunky dory but nobody changes pistons for shifts and giggles
Old Feb 14, 2012 | 03:29 PM
Berlinetta's Avatar
Are you good with a wrench? I will send you a build i used,once i find it. Are you planning on heads aswell? A good pair of aluminums will run you a pretty penny?
Old Feb 15, 2012 | 12:02 PM
the guy im buying the engine from started to take apert the engine not sure why he took out one piston but hes the one who is gonna help me rebuild it and put it in
Old Feb 15, 2012 | 12:03 PM
yeah please send it ive been following a couple just kinda lookin around
