need help
so i decided to trash my 305 and put a 350 in it just looking for some opinions on what i should do engine and suspension its a stock 1991 camaro rs
If your suspension is not bad I wouldnt change anything, and with the engine do you want build sheets? What do you want, street demon, track racer, decent on gas? Tell us everything you expect.
I'm looking for some good performance the 350 I'm buying is missing a piston so I'm replacing all the pistons
How much are you willing to spend?
Are you planning for N2O or charging the vehicle? What is good performance to you? (In my mind decent performance is around 350hp for a 350sbc) |
Originally Posted by dmurray1990
(Post 606035)
why is the engine missing a piston? |
The piston was removed b excuse the guy who has it was gonna replace them but he had got rid of the car and has the engine in his garage its from a trusted friending of the family engine is clean and everything and it was running when he took it out and as far as n20 most likely not and maybe charging it way later down the road rite now I'm just looking for some peoples opinions on what to do something thsts not crazy expensive but not cheap either
I'm sorry but I'm still stuck here
you don't change pistons just for shifts and giggles why is it missing a piston ? you want to believe that it's all just hunky dory but nobody changes pistons for shifts and giggles |
Are you good with a wrench? I will send you a build i used,once i find it. Are you planning on heads aswell? A good pair of aluminums will run you a pretty penny?
the guy im buying the engine from started to take apert the engine not sure why he took out one piston but hes the one who is gonna help me rebuild it and put it in
yeah please send it ive been following a couple just kinda lookin around
