Leaking Valve Covers
Old Mar 23, 2007 | 07:44 PM
83 Z28's Avatar
Default Leaking Valve Covers
I have a 83 Z28 Camaro. The valve covers have leaked for ever. I am sick of having to replace the gaskets because it is so hard to tear it down to that step. I have tried several types of valve cover gaskets both rubber and cork. I am wondering what to do. This is angering me because it seams to me that I am having to change the gaskets about every 2 years. Any suggestions would be appriciated. Thankyou
Old Mar 24, 2007 | 12:01 AM
89 Iroc Conv's Avatar
Default RE: Leaking Valve Covers
I can think ofthree things that might make your valve covers leak excessively. First thing is maybe the covers a warped, or maybe you aren't pulling enough vaccum on the crankcase via the pcv valve and it is pushing oil past the gasket or maybe your oil drains in the head could be clogged letting oil puddle around the gaskets. These are just some quick ideas of things you could check.
Old Mar 24, 2007 | 03:23 AM
74454bb's Avatar
May 2007 ROTM
Also check to make sure that you did not counter sink the bolt holes.Take off the valve covers and make sure the sealing surface is smooth and that the holes are not counter sunk. If so use a hammer and something flat to smoot them out. Most of the time the covers are torqued down to hard and it counter sinks the mounting points. They only need to be tight enough to seal.
blink18236dude
Mar 16, 2007 01:48 PM
microkid
Nov 12, 2006 10:21 PM
carguylt1
Nov 7, 2006 05:38 PM
69camaro1
Oct 11, 2006 02:15 PM
nnickty
Aug 22, 2006 02:25 AM
