help no power
Old 03-15-2011 | 09:31 PM
tjcamaro88's Avatar
Default help no power
hey i have a 88 305 tbi when i got the car it ran fine as i been driving it more i noticed arount 3000-4000 rpm i have no power no matter how much i pressed to gas pedal it got worse as i drove more before i knew it it would do it @ 2000 rpm it sounds like its breaking up bad tried changing the fuel filter that helped for about a week then the same thing no power wont rev up past 2000 rpm bucking any ideas to wat it is before i start dumping money into parts that i dont need? also it is running lean smell of unbrunt fuel out of exhaust pipes
thanks Tim
Old 03-26-2011 | 07:56 AM
tjcamaro88's Avatar
update did a fuel pressure test and its dropping down to 3 psi after 3 grand time for a new fuel pump
Old 03-27-2011 | 07:16 AM
GLENN M's Avatar
running lean and raw fuel coming out exhaust pipe dont go together,if you hadnt fixed it i would say plugged cat converter
MaxTheKiing
08-23-2010 03:21 AM
rbeard
82-92 V8 Tech
08-09-2009 12:11 AM
dkblind87
LS Series Tech
07-27-2009 05:35 PM
IBADRIDE
07-13-2006 01:44 AM
Quick Reply: help no power
