Help! Where to look for budget roller cam
Old Mar 31, 2011 | 05:48 PM
1989_RALLYSPORT's Avatar
Default Help! Where to look for budget roller cam
OK looking to go cheap on my 305 till the 383 done
now i want to know if a lt 1 cam will work in my roller 89 305? and if its worth the time to swap out
should i use my vortec heads with it? it has reg 350 center bolts on it now
or if anyone knows where i can get a decent to stout street strip roller cam let me know.
Old Mar 31, 2011 | 05:54 PM
oh ya havent pulled pistons or checked the bores but what size over rings should i get .0200 or .0300 can get ful set for re ring up to .0600 over for $25
Old Mar 31, 2011 | 07:49 PM
djs383's Avatar
Just a question, if you are building a stroker, why would you even put a single cent into a motor you are going to toss? Or is the stroker way down the road? It just seems like a lot of work to me.....
Anyways, your cam selection is pretty limited to your heads capacity....and your computer in handling that fuel/air delivery change.
Old Mar 31, 2011 | 08:18 PM
383 wont be in till next year... but im tired of slow i want to be a little faster i can get atleast 100 extra hp out of a top end swap maybe more. combined with my eaton lsd 3.73 and tci super street fighter 700r4 IT will HOPEFULLY be more fun
Old Apr 1, 2011 | 08:43 PM
microkid's Avatar
March 2011 ROTM
Technical User
save it for the 383. roller cams are very expensive, and a budget one will probably just break or wear out quick
mikeorwan
General Racing/Tech
Jul 2, 2010 01:50 PM
Zzz28sleeper
Sep 25, 2007 04:59 PM
Altekameraden
Sep 13, 2007 06:22 PM
Kardon507
Jan 9, 2007 04:32 PM
92camaro305
Jan 2, 2006 01:22 PM
