Help...3G's what to do?!?
Old Jul 19, 2008 | 10:58 PM
kwwrestler's Avatar
Default Help...3G's what to do?!?
Ok look i got a 2002 Camaro SS..with just a K&N Airfilter..and i got $3,000 to spend....and i want to get maximum horsepower for my buck... so what should i do and what should i get...?!?!
Old Jul 19, 2008 | 11:14 PM
MadMikeZ28's Avatar
Default RE: Help...3G's what to do?!?
And you ask this in a third gen section because...... Maybe posted the same ? all over
Old Jul 20, 2008 | 09:03 AM
SpecterGT260's Avatar
Ninja Administrator
i can send u my paypal address
Old Jul 21, 2008 | 07:42 AM
383superstreet's Avatar
with the stock heads you can get a cam that is no bigger than .430 otherwise your valves will float at higher rpms. i would just do a bigger cam and get an intake set up off of an LS6 motor with a bigger throattle body, then get a computer chip, if you are doing the work yourself then you might be able to get bigger injectors but when your going for big power there is a big price tag. you can also get the heads milled to up the compression.
Old Jul 22, 2008 | 09:00 AM
brassknukl's Avatar
ORIGINAL: SpecterGT260
classic
btw why is this in 3rd gen v8? [sm=chairshot.gif]
