grinding in reverse?
Old May 20, 2007 | 11:18 AM
TorqueTilla's Avatar
Default grinding in reverse?
im having a problem with shifting into reverse? it seems everytime i do it the gear grinds, i sometimes have to wait and put it in very very slow for there to be no grind. none of my other gears are like this, ne ideas on what it could be? btw its a new clutch
Old May 20, 2007 | 11:56 AM
ghotachevy's Avatar
Default RE: grinding in reverse?
prob a bad syncro
Old May 20, 2007 | 12:12 PM
350rs's Avatar
March 2008 ROTM
are you comming to a complete stop before taking the car out of gear? NOT pushing the clutch in since you need to do that to come to a stop, but actually taking the car out of gear before stopping? If so, just wait till your stopped before switching gears.
Old May 20, 2007 | 06:05 PM
MadMikeZ28's Avatar
Maybe your clutch needs bleeding. try putting itno first or second then going to reverse
Old May 21, 2007 | 10:26 PM
import_eater's Avatar
My 86 IROC Z28 does the same exact thing. I just put it into 5th then into reverse, with no problem. I have no idea why it does this either.
Old Jun 20, 2007 | 11:59 PM
mikem290's Avatar
i have the same problem with my 86. It has something to do with a pressure plate or w/e. If you put it in 1st THEN put it in reverse, it wont grind, or at least it doesnt for me.
Old Jun 21, 2007 | 12:25 PM
brandino's Avatar
I put it in 5th and then it goes right into reverse. It's something about stopping the gears; either that or you can wait in neutral for 5+ seconds for them to stop.
Old Jun 21, 2007 | 09:49 PM
microkid's Avatar
March 2011 ROTM
Technical User
there shouldnt be a synchro for reverse, should there? try double clutching it first. clutch in, out, in and hold for 3 seconds then put it in. my geo does it all the time and needs double clutch for reverse
Old Jun 27, 2007 | 02:53 PM
dennis j's Avatar
there is no syncro for reverse, what fluid are you using in the trany ? when i got my 5 spd some one put gear oil in the trany and it had the same probem (too thick) (i got that out quick) and am now using gm syncromesh fluid
Old Jul 10, 2007 | 01:51 AM
80sbaby's Avatar
I thought first and reverce share the same synchro?? I think thats what I learned in school.,lol. Maby the gear it self or linkage?
