distributor vacuum advance line hook up
Old May 7, 2006 | 01:35 AM
sewerrat's Avatar
Default RE: distributor vacuum advance line hook up
WOW Sick, great explanation! That was one hell of a Advance timing 101. I've never heard of adjusting intial timing that way, but I'm gonna do it that way from now on. So back to my first question is I should hook it up to constant manifold vacuum after adjusting, right?
Thanks for the input everyone,
mike
Old May 7, 2006 | 02:53 PM
SickSickSick's Avatar
Constant Vacuum. Use The Vacuum Port At The Front Right Base Corner Of The Carb. Sick
Old May 8, 2006 | 07:07 PM
So Since My Cam Duration Is Over 300 ... You Think I Would Be Better Off Without Vacuum Advance? Sick
With your cam you should be able to disable the vacuum advance and just work with the mechanical adavance, especially if are using the car mostrly for racing. I know you don't like to use timing lites, but you can use one to see if the vacuum advance is really doing anything. With engine idling, the timing lite connected and aimed at the timing marks, pull the vacuum adavance hose from the distributor and keep it from sucking air. If the timing changes, then the vacuum advance is actually doing something. if not the vacuum advance is just going for the ride. In any case, at WOT the vacuum advance is out of the picture.
Old May 9, 2006 | 12:03 AM
Kewl. I Have A Whole Assortment Of Advance Springs I'm Gonna Play With As Soon As Get Some Consistant Runs. By The Way ... Thanks For The Strut Advice. I Bought A Set Of Lakewood 90/10's made A Big Difference. My Stock Struts Were Completely Flat. Sick
Old May 13, 2006 | 10:28 AM
JLT25's Avatar
You should connect your advance to ported vaccum, this way you will get more advance as you rev the motor. z28PETE sounds like he knows what he's talking. I agree with what he's saying.
Old May 13, 2006 | 11:39 AM
You Go Grandma !!! Get Those Miles Per Gallon. Sick
Old May 13, 2006 | 06:30 PM
Well ... Looks Like I'm Gonna Have To Eat This One. Through My Whole Life Of Working On And Driving Street Vehicles I Have Always Believed That Constant Vacuum On Vacuum Advance Gave You Better Throttle Response. Well Today I Have To Admit I Was Wrong. I Tested My Race Engine Most of The Day And I Have To Confess Ported Vacuum Gives You Better Response Than Constant. I Always Knew That Ported Gave You Better Gas Mileage But, Falsely Believed That An Engine Reacted Faster With The Advance Constant. Through Trial After Trial Constant Vacuum Caused A Hesitation When Stomped From A Dead Stop. To Those I Have Lead Astray My Apologies. I Guess You Can Teach An Old Dog New Tricks. Sick
Z28Camaro98
LS Series Tech
10
Jun 3, 2012 06:52 PM
gfrench
Mar 8, 2011 03:04 PM
gfrench
Nov 5, 2010 08:06 PM
nitrojunkie
LS Series Tech
Oct 7, 2010 10:57 AM
ChrisDK17
Mar 19, 2006 11:29 AM
