Distributor module location
Old May 9, 2010 | 11:41 PM
87rsmaro's Avatar
Default Distributor module location
i just picked up a 85 z28 5.0 an the kid i got it off of said it needs a distributor module i have no idea where it is or what would be the best way to fix this problem any help would be appreciated thanks
Old May 10, 2010 | 01:03 AM
i believe he was talking about the ignition module. its inside the distributor.
Old May 10, 2010 | 08:54 AM
Are you getting a no spark problem to indicate the module might be the problem? And yes, the module is under the distributor cap. It's a black, flat rectangular-ish part with two electrical prongs at an angle, that the harness plugs to. If you do replace the module, don't forget to put the silicone grease (supplied with a new module) on the metal part on the back mounting side.
jml2002
Mar 5, 2013 04:25 PM
midrange
Mar 13, 2010 01:47 PM
ILYA
Nov 25, 2007 09:38 PM
mwesthoven
Sep 7, 2007 09:22 PM
denk98
Feb 6, 2006 02:10 PM
