corvette servo??
Old Oct 25, 2007 | 10:16 AM
smithdjr's Avatar
Default corvette servo??
so im thinking about puttin a corvette servo in... will it help me out alot or is it a waste??? will it help me with speed?? torque?? or anything?? please let me know if anybody recommends it... Thanks...
[IMG]local://upfiles/10146/840B0139BD6D438CB70A54B4010891AF.jpg[/IMG]
[IMG]local://upfiles/10146/8C48827D906B47968296C561615D434A.jpg[/IMG]
Old Oct 25, 2007 | 01:33 PM
Default RE: corvette servo??
The Corvette servo has more surface area, enabling more pressure to be applied to the band, which gives a firmer 1-2 shift. I have a 91 RS, and it goes well off the line, but shifts like a slug into second. A servo upgrade is a fairly simple trans upgrade without having to drop the pan.
Old Oct 26, 2007 | 09:58 AM
smithdjr's Avatar
ok thanks for the reply bro... im gonna put it on cuz i got it for free! and im also thinking about puttin a shift kit in it... should i do them both or just one of them??
Old Oct 26, 2007 | 11:03 AM
Some people like to do both at the same time, it depends on what you want to do with it...fry the tires with every shift or what? Keep in mind that even though the claim with a trans kit is that it's supposed to make the friction components of the trans last longer due to less slippage, banging the shifts puts more stress on other things such as the trans mount, u-joints and rear end. Decide how radical you want to go and make sure your other components are strong enough to take it. I would first start with the servo and see if that gives you what you're after.
Old Nov 4, 2007 | 01:16 AM
Dougs1990rs's Avatar
i didn't notice any diference in mine but i also have a 3000 stall.
ronusmc
Mar 30, 2015 01:36 PM
mgg4591
82-92 V8 Tech
Sep 7, 2011 04:51 PM
hevymetalg
Mar 24, 2009 06:57 PM
buddywackos
VS
Jun 22, 2007 03:13 PM
