Chugging at high speeds.
Old Sep 20, 2009 | 02:01 PM
Hoboman802's Avatar
Default Chugging at high speeds.
Hi, I'm new here and couldnt find anything resembling my problem. When I drive on the highway, at around 65-75 mph, my 89 V8 rs camaro starts chugging. Kind of like an out of gas chug, but i had a full tank. Anyone have any ideas why? Thank you in advance for your help.
Old Sep 20, 2009 | 02:24 PM
fuel filter or pump.
Old Sep 20, 2009 | 02:25 PM
Hoboman802's Avatar
if it were those wouldnt it chug at lower speeds as well?
Old Sep 20, 2009 | 03:15 PM
higher speed means more fuel. if the flow in not as it should be then it will not go. try the fuel filter and see if that has any effect and also dump the contents of the filter in a clear container and see whats in it if anything.
Old Sep 20, 2009 | 03:34 PM
check your spark plugs and wires also. higher speed also means more electrical current.
Old Sep 25, 2009 | 08:20 PM
microkid's Avatar
March 2011 ROTM
Technical User
chugging can also be from an incorrect fuel ratio. is it carbed, tbi, or tpi?
jbcamaro
LS Series Tech
17
May 18, 2010 07:14 AM
kinder62
Sep 24, 2009 07:12 PM
Jonny Dubyah
Sep 20, 2009 12:55 PM
camarokid1
May 20, 2007 03:17 PM
nikki1228
Sep 1, 2006 05:09 PM
