Changin light for instrument panel
Old Jan 1, 2010 | 10:46 PM
camarobarbie91's Avatar
Default Changin light for instrument panel
Ok, so my light behind my speedometer went out sometime ago & I know how to change it once I get back there to it, but gettin to it is the problem... Where I am runnin into problems at is gettin the light switch off to get the plastic cover all the way off! I have tried it several times & got frustrated & even had others to try, but no luck. If anybody has an idea or an easier way to do this then I am willin to try anything!
Old Jan 3, 2010 | 10:33 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
you mean the headlight switch?
Old Jan 4, 2010 | 02:29 AM
mighty mike's Avatar
if u have tilt steering tilt it all the way down and tilt the guages toward u a lil while turning it to the right. its a REALLY tight fit but it will come out. if u dont have tilt id say remove the steering wheel.
Old Nov 16, 2010 | 12:40 AM
sebastianwebber's Avatar
This link might help since you are gonna remove the instrument cluster panel, might not be the right vehicle but looks very similar on replacing some parts attached to it.
http://www.ehow.com/video_2327717_re...from-dash.html
HappySalesman
May 6, 2014 04:18 PM
Racer
May 16, 2011 03:34 PM
AF1
Apr 7, 2011 08:01 AM
camarofreak1990
Apr 1, 2009 12:25 PM
ryan88z
Dec 30, 2007 01:34 PM
