alternator not charging
Old May 10, 2009 | 03:17 PM
chadriley5's Avatar
Default alternator not charging
i recently installed a 409ci small block into my car.the stock engine was a 305. i used alot of the wiring harness from the original engine and all accessories. the car is no longer tbi it has a carb now.the alternator will not charge the battery. i took the alternator and had it checked 3 times and it checked out out fine.has anyone else had this problem?
Last edited by chadriley5; May 10, 2009 at 03:20 PM. Reason: wrong forum please delete
Old May 11, 2009 | 12:55 AM
mtn_maro's Avatar
check your wiring. maybe you accidentally cut a wire or your connections are bad or something
Old May 23, 2009 | 08:55 AM
chadriley5's Avatar
i finally figured it out,the big wire coming off the alternator wasnt getting power to the battery. i just ran a new one thanks
djsquare1
Jun 13, 2013 02:53 PM
jlala
Oct 21, 2009 06:36 PM
chadriley5
82-92 V6 Tech
May 22, 2009 11:47 PM
tode5tool
Dec 18, 2008 09:25 AM
ben50520012000
Apr 3, 2007 06:20 AM
