Ac problems
Old Jul 14, 2006 | 10:08 PM
judysz's Avatar
Default Ac problems
Can anyone help me please? A couple of months ago my low coolant light came on and my car overheated. The same day my ac quit blowing cool air. I took it to a shop and they flushed my radiator and cleaned my sensor. Put 2 cans of freon in and ac still would not cool. They disconnected my battery and reset computer. It blew cool until today and we have disconnected the battery and reset the computer twice, but for some reason it will blow cool for a little while then it stops. Any ideas on how to solve the problem.
Old Jul 15, 2006 | 02:55 AM
94Z28SHAKER's Avatar
Default RE: Ac problems
might not have enough freon staying in the system to activate the circuit, sounds like a leak, probly the condenser, when you turn the car off with the a/c on does it hiss like there is air coming out somewhere, if it does thats probly your problem.
Old Jul 16, 2006 | 01:28 PM
Good possibility you have a leak and the freon is leaking out. As car get older the seals and hoses dry out and allow the freon to excape. Your best bet would be to go to a shop that specializes in AC and have them test the system.
Old Jul 16, 2006 | 10:32 PM
MadMikeZ28's Avatar
What no one adressed was that your car overheated. If you engine cooling fan is not working it is not pulling air through the radiator or condensor. You need air to go through the condensor for the a/c to get cold. Do you have an electric or engine driven fan? Do you have coolant in the radiator and exspansion tank?
Old Jul 20, 2006 | 05:57 PM
Good point MadmikeZ28, if the fan doesn't work, then the AC won't work too well either.
mp734
Nov 6, 2013 11:54 AM
nmallory56
Jul 21, 2009 03:34 PM
IZZY1967RS
Jun 19, 2008 10:29 PM
jdubs1813
Nov 12, 2007 04:16 PM
Nov 11, 2007 11:56 AM
