92 Z28 Convertible Door
Old Mar 17, 2009 | 03:43 PM
alxhrd12's Avatar
Exclamation 92 Z28 Convertible Door
Hello I'm New to the forum and I have a problem with the door on my grandfather's Camaro.
THE DOOR WON'T CLOSE!!
Theres a little plastic/rubber piece in the door that been "flipped up" and will not let the door close. I opened the door, sat in my dream car, closed it.
Got in the passenger door, opened it, closed, but when I re-opened it, I haerd a "ping." Now this thing is in the way.
This car is about to be mine and its in mint condition! I want to fix it with out him knowing in the first place!!
HELP!!!!
Old Mar 17, 2009 | 04:31 PM
Are you talking about the latch mechanism in the door?
Sounds like the latch may have rotated into the "closed" position. And now it's smacking the striker on the door jamb?
Lift up on the outside door handle while trying to pry and rotate the latch back open. If it doesn't click and stay in the "open" position, then your latch is messed up.
I have a feeling the latch may be bad, because they usually don't close shut on their own.
Old Mar 17, 2009 | 04:35 PM
alxhrd12's Avatar
its the latch mechanism, internal parts.
Old Mar 19, 2009 | 09:12 AM
adirtypoostick's Avatar
From: IN, or hell whichever, wait, its too cold to be hell
my old trans am did this every once in a while. I would lift the handle and pull the locking mechanism and spray with some wd40 to keep it working for a little while.
Old Mar 22, 2009 | 06:08 PM
alxhrd12's Avatar
problem solved, i did everything but pull the handle and try it
but its fixed now so i cant sleep at night
Old Mar 22, 2009 | 06:25 PM
alxhrd12's Avatar
thanks
Old Mar 22, 2009 | 08:52 PM
You're welcome, glad you got it to work. Sometimes it's easy to overlook the obvious things.
Nice looking car by the way.
Old Mar 23, 2009 | 07:55 PM
alxhrd12's Avatar
thanks
CheVy_R0aRrR
Jun 8, 2011 01:39 AM
snakewack
May 9, 2009 12:43 PM
schoenborn
Aug 1, 2008 04:55 PM
triumph601
Apr 11, 2008 02:58 PM
Luggy442
May 10, 2007 02:20 PM
