89 iroc throwin a code 12
Old Mar 9, 2009 | 05:00 PM
manifold's Avatar
Default 89 iroc throwin a code 12
i have an 89 irocz i bought it from a guy who had no clue what had been done to it. any ways the engine has supposibly been replaced and whoever did it was retarded as far as wiring. i bought it not running my brother-in-law and i got it running but now it doesnt want to idle. it is a 305 tpi. i used a paper clip and only get code 12. any ideas? check engine light never goes off. i have already replace thermostat and radiator because it was over heating.
Old Mar 9, 2009 | 05:31 PM
Saint_Ali's Avatar
code 12 is flashed first before any other codes to let you know it is working, code 12 is not a malfunction code
Old Mar 9, 2009 | 05:33 PM
Saint Ebony's Avatar
Third Generation Moderator
March 2010 ROTM
Code 12 is always there. It's not indicative of any problems- it just shows the system is working. But, if the wiring was done really poorly, that'd be the first thing I'd check into.
Edit: ninja'd :/
Old Mar 9, 2009 | 05:47 PM
Actually code 12 does stand for something. It's telling you the ECM isn't receiving a signal from the distributor. But that's because the engine isn't running. Code 12 is normal.
Old Mar 10, 2009 | 09:39 AM
draggo144's Avatar
I'm having the same problem with my 91 w/ the 305 tpi. I have to give it gas for it to idle until it warms up then it runs just fine. I think the problem is the ECU is stuck in closed loop... or open... whichever is the one where the car starts running off the O2 sensors and idles itself. I was told that a few ignition cycles should relearn the idle but that never fixed it. I still have the same prob and Im about to give up and buy a scan tool to relearn the idle lol
sobo
82-92 V8 Tech
Jun 2, 2011 05:58 PM
AMP3D
May 11, 2011 08:58 PM
1983camaro
82-92 V8 Tech
Feb 27, 2011 03:26 PM
350rs
May 16, 2007 09:02 PM
86irocmn
Oct 11, 2005 02:59 PM
